throwinafiat
1997 Fiat 500f
i am putting a new 5 speed transmission and the abath motor (i believe this is my first fiat this old i have worked on so im learning) since the car was originally the 4 speed transmission i had to cut the linkage down to accommodate the longer tans however i can only grab 2 gears with the shiftier hooked up and with the shiftier disconnected i can stick and screwdriver in the bolt hole and i can still only shift forewords and backwards into 2 gears. every other gear is inaccessible. i can put the transmission into neutral and twist the arm (that comes out of the transmission) and feel to sets of detentes but only move forewords and backward when the arm is 90 degrees.
has anyone had this kind of problem or something similar. any info will help i appriciate it
also forgot to mention the car shifted fine with the old transmission again thank you
