Doblo New to Fiat and Fiat Forum - 2008 Doblo
fazen
Hello all!
Newbie here, just got myself a 2008 Doblo Dynamic with 44k on the clock for £5k.
I seem to have the same issue as many people do upon reading this forum, my radio stays on!
Ive held the menu button down, but doesn't do anything on mine. Its the Fiat 223 Blaupunkt CD/Radio.
Ive had it out this morning and there is a switched live at the back of the radio, but cant make the radio turn on and off with the key! Annoying!
Also the fan doesn't work on 1,2,3 but it does on 4, dealer is sorting that for me, its a resistor apparently.
On the whole im very pleased with it, got a bit of punch for a 90bhp even when full.
Just the niggle with the radio which appears to be "normal".. there must be a fix for it!!!
fazen.
Hello all!
Hi , and welcome to FF, :)
charlie - Oxford
iv got a new fiat doblo 14.00
the stop start has never worked since i had it
took it in and the guy told me not to have the radio,heater,lights on.
he told me to drive at-least 45 minutes a day.
to me this stop start is a wast of time.
any one els had the problem?
it done 3800 miles on the clock
hi Gordon, and welcome to FF, :)
have a look in the 500 section if you want all the pro's / cons of the start/stop on our little engines..;
bottom line = it's an aid that saves you money on RFL / VED,:)
even if you push the dashboard button to disable it, ;)
mine has never worked well, :(
BUT i've started to use it again lately .. and it actually works o.k.,
( I disabled it when the restarts occurred every 15 seconds - waste of time :bang:),
but it will now sit for 3 mins before re-starting..,
usually works well after a 2 hour m-way journey though..!!,(y)
what use does yours actually get..??, :confused:
charlie - Oxford
