Technical New sump fitted & horror revealed
KeithT
Newton Swansea
More fun with my recently acquired Punto MK1 60S I have replaced the front disks & pads.
The sump had rusted & was leaking so I replaced it with one I had on the shelf I'm glad I did as I have now found out why my oil light was slow going out on start up.:eek:
3912538913
http://www.flickr.com/photos/16355930@N02/3912538913/
this is the oil pick up the sludge was like concrete!
Make you wonder when the oil was last changed by the previous owner!!!?
I have filled it with diesel oil as it is high in detergent & should help to wash out some of the sludge I'll run it for 1000 miles & change the oil & filter again.
I've also sorted out a slight rear end ding (Bang?) & replaced the tail gate it was a bit twisted.
I've got another possible problem I replaced the fuel filter & had a problem because the pipe from the tank was a bit short made changing the filter difficult I tried to pull a bit more pipe & unfortunately it has broken the crappy plastic pipe stub on the tank unit (bu***r) I have repaired it with a sleeve pushed & superglued into the broken parts but I will probably need a new tank unit - do I have to replace the whole thing? any suggestions?
All good fun! (not)
