P
patrick
Just been sent this info via email:
You know those new electronic signs on the M4? Well they were switched on
by some transport minister on Tuesday. Now the bad news, they are rigged
with the SPECS speed cameras.
SPECS is a camera based system. As you go past a camera software detects
and reads your number plate. When you go past the next camera, it detects
and reads your number plate again. It knows how far apart the cameras are
so it can work out your average speed between the two cameras.
The system is fully automatic and will automatically issue a ticket without
any form of human intervention. It does this for every single vehicle that
passes a camera! You will not know you've been nicked as the cameras don't
flash. There's no film in them either, they're digital. Images of you in
your car, together with the date and time are stored on disc (I assume they
only keep them if you've been nicked).
It works 24/7, 365 days a year, and theoretically, there's absolutely no
limit on the number of tickets that it can issue.
The whole section of the M4 between Theale (J12) and Membury Services
(between 14 and 15) is wired, both ways.
It is believed that the system is set to trigger a ticket at 78 mph.
The bad news gets even worse. For those who've got radar detectors, they
won't work. SPECS is entirely passive, there's no radar or laser beam to
pick up.
If anyone wants to be brave, we can do an experiment with small number
plates. I don't know what the upper speed limit is on SPECS either, on
GATSOs its about 175 mph, above that it can't detect you!
pick up.
