Paolo66
Established member
- Joined
- Feb 6, 2013
- Messages
- 1,004
- Points
- 310
So I decided to upgrade to an aluminium 3.5lt oil sump from the standard fit steel one. I figured the extra oil volume and different material would allow for better oil cooling. As part of the upgrade I am also going to fit an oil temperature gauge and sensor. I was planning on just using a t-piece from where the existing pressure sensor is and wiring it up. I've a couple of questions for you guys that have already done something similar.
How do you wire up the sensor to the gauge? Does it need a power supply or does it just work on electrical resistance?
Once I've got it wired up what temperature will the oil be for normal average running?
Thanks in advance
Damian
Thanks in advance
Damian
