Ducato (Gen 3) New Member
plumbomb
Hi my name is Trevor and purchased a 2013 motor home on a Fiat 130, very impressed with the Fiat so far, im a self employed plumber and drive a Vauxhall van every day for work.Probably look at a 130 when im changing my van.The only thing is ive knocked the internal mirror off, its a bit strange as it seems to be in two parts,there is still a slim peice of metal still stuck to the window. Im thinking of glueing it together with some supper glue !!!
Hello Trevor. The mirror is in 2 pieces. The flat metal piece stuck to the window is keyed on both edges and the mirror itself slides onto this and locks in place.
Has the mirror broken or the bracket on the window?
The mirror is often for sale on e-bay usually about £25.
Mike
I've tried to glue these with superglue unsuccessfully in the long term. At the very least you need a solvent free superglue with activator.
Mirror is probably ABS so MEK solvent aka pipe cement will put the broken bits back together like new if you have all the pieces - you only need a sniff of it. You can also dissolve some other ABS in acetone to make ABS glue.
