Technical New Coil Pack & Plug Leads, Still misfiring.
watts320
Ive had a new set of plug leads, new coil packs.. still misfiring, what am i doing wrong!!!? :(
Next thing I can only suggest is spark plugs.
I had a code read before and it said coil pack a.. changed both n still misfire. Hopin its not my ecu.
When I had this, my head gasket was gone :( - so a compression test would quickly rule that out if you have a tester handy.
Try swapping over coil packs and see if the misfire moves. Or you could check for a spark at the end of each lead manually like this :
And disconnect the battery when playing with the coil packs so you do not spike the ECU :p
Certainly worthwhile considering other causes of misfires other than ignition, but I think the coil pack A fault needs following up. Primary side is the low tension side (connector and leads from the ECU to the coil), secondary the high tension side (plugs, leads, general filth).
Either can be (but is by no means necessarily) internal to the coil.
Injector coils can simulate a miss fire feeling, usually great until it heats up then the coil inside the injectors starts braking down/shorting, but might bring up an injector fault code, the one we fixed never brought up a code. Just throwing it out there . . . .
Thanks guys. Can i ask. My new plug leads oon the ends that go into the coil packs they have 45w 70w i think 86w n something else whats the purpose of that?
Im getting no sparks to any coil pack I put at the rear, the front one no matter what coil pack always gets sparks, its just the back coil pack which ever out of the 3 I have i put on, there is no spark.
Trace the low tension wires right back -- look for a break, chaffed insulation, etc.
If you don't find one, break out the multimeter and do a continuity check.
If that doesn't turn anything up, Check the big fat connectors at the ECU (clean, make sure no pins are pushed out of place or bent).
Failing that, the ECU is suspect.
