Technical New cambelt fitted
Hi all,
got a new cambelt,tensioner,and water pump fitted last week to my punto mk2b.
now when i rev the engine it is making a whining noise,
any ideas what this could be?
tony
So Not a floating tensioner.. But a fixed one
Potential the tension is incorrect..
I'd say so. If not a spring loaded automatic type, then you've got to know what you're doing if it's to be tensioned correctly. Overtensioned belts typically give off a whining noise in protest. Needs fixing or water pump &/or tensioner bearings are likely to fail prematurely.
