Hi, I recently noticed the right front wheel of muy Ducato 244 2.8 jtd was hotter than the left one after a few kilometers.
I rase up the vehicle and saw the wheel was braked.
The caliper had lot of rust so I replaced it.
When l loosened the brake hose, I noticed no much liquid went out but I Installed the new caliper thinking after bleeding all will be correct.
Well, the thing is now the caliper is totally stuck.
It doesn't relax at all.
The pedal rests hard with pression.
When bleeding, liquid comes out, not air.
Do you think it's the hose that may be a little clogged?
May be the pipes from master cylinder, the proper master cylinder?
Thanks...
Thanks...
