Peter Rawlings
It has been a while since being on the forum…but I have hit an issue and need some advice…
My car: Panda 4 x 4 Cross, twin air, 2016, 113,000 miles. MOT due 6.1.23
Car serviced by brilliant mechanic at local garage since 2019 (Fiat dealership over an hour away). The mechanic has done some excellent work on the car for the last three years, throughout the pandemic etc…so..
About 3 months ago the original battery died (at about 109k) and replaced by a new, high power battery. A month ago the new battery was flat after the car had stood on the drive for three days. Mechanic charged it to full, did a complete battery test: battery ok. He could not find the fault, believed that something was draining it but has not got the Fiat diagnostic kit needed to discover the problem. I decided to stop using stop/start and the car has been fine since then…until..I parked the car in the drive on Thursday and have not driven it since, so yesterday decided to scrape the snow off and just start it to run it a bit and clear the rest of the snow and ice. No start! The battery is completely dead again. I realise that it is very cold but this should not happen.
The mechanic is going to come later today or tomorrow to charge it up and take it back to the garage (just 750 metres away) to run his check on the battery and scratch his head again. Like me!
The Blue and Me unit failed 15 months ago but I decided to not replace it and the mileage is still being recorded for the MOT etc. Up until the original battery failed I had no electrical issues other than this and do not believe that this might be the cause of the battery drain, but wonder if I am correct? The car has been running fine except for this fault…
Ideas, suggestions, advice welcomed !
cheers
Pete
cheers
Pete
