Need the key code for the connect nav
mitzu
Bucharest
Hello, I need the key code for my Fiat Stilo, the head unit is a Magneti Marelli sn 735337571.
I know a german homepage, where they will officially give you your pincode. But they will not give it to anybody...you must be a dealer.
Homepage is:worldwide web pavlek . de (It says, I'm not allowed to post an URL, because I have at least 5 posts - but it's my first one here?!? Thats why I wrot the address that way) maybe they can help you?
Good luck
Kay
Hello, the number you mentioned is not the serial number but the part number of the Connect Nav - the serial number is build up with 9 characters : the first is always a number and the rest is alfanumeric (i.e. 1+5C2TH7C / 16ZCL1AB / 3TSC19P4D etc.)
If you have a good dealer (like me) you will only need this serial number and 47 euro including VAT to order a code card for you.
Of course it must be obvious that the Connect Nav was not stolen....
good luck,
yellowstilo
if you are andy with a screw driver open the unit and remove the battery is a flat 3232 this way you are open cercuit if the code is 4 digit press1234 if is 5 and the 5 12345 this will reset unit dont replace battey
did you try this yourself on a Connect Nav system? I guess the code is stored in an Eeprom so it keeps its code in memory without the battery?
yellowstilo
all unit in any cars cams with manufactory code not car manufactory the codes are 1234 and 5 try and see if i am wrong well SORRY
Hi again,
The model is: Magneti Marelli sn 735337571 , 16XD1894C , NPX00+94C. Fiat Stilo. Eprom 24LC64.
This is all I have on it.
I have already tried to my local dealer (AutoItalia Romania) with no luck. They gave me a key card code, but the unit doesnt recognize this code.
Thanks for your support. I will keep watching this thread for updates.
I have been to my local dealer in Romania (AutoItalia) and they gave me a wrong code. They gave me a key card with a code that is not recognized by the unit.
They looked all the serials of the car and unit.
