General need some ones knowledge
Coventry (near Birmingham
after ages ive finally pulled my finger out and sorted the 1242 wiring. last thing i need to do before i can sell it is weld a plate in the boot, want to do this my self if i can so can any one tell me what thinckness of metal i would need?
thanks (y)
arseofbox
Principality Retained :)
Midlands
2mm/3mm if its only in the boot i shouldnt think youll need much thiner.
2-3mm....:eek:..are you crazy??
The bulk of the car is comprised of sheet that I believe is around 0.7-1.0mm thick.
Im sorting out the rear arches, using some 1.1mm sheet and that looks a little too thick (only ~0.5mm over), but its not bad enough to lose sleep over.
Maidstone
Yeah 3mm is way too thick. You will prob blow holes in the body before you will get it to stick. As said before 1mm is fine- thats what I would use anyway.
Rich.
Brooky
Well-known member
Lancaster
I'll be welding some 3mm plates into the back of my cinq,but thats a different story:slayer: :slayer:
OxO
Newton aycliffe
3mm aint that thick. i make parts for the new civic and loads of other cars and quite alot of the steel we use is thicker than 1mm for eg t5he new civic type R doors are 2.4mm thick
also i used 3mm thick to weld the floor pan up on an old mini and it welded fine
rallycinq
Autotest Special
Lake District....Moist
Drive round the countryside with a set of tin snips in the car. When you see an abandoned washing machine, cut a plate out of that.
Brooky
Well-known member
Lancaster
Thats what my mini is half made out of. dish washers,washing machine etc(y)
Those doors on the new type R's must weigh abit is there made from 2.4mm steel
