00 - throttle position sensor
01 - unsure, i think its the idle control valve
02 - again unsure
03 - vacume pipe by the look of it
04 - dunno
05 - dunno either
02-inlet air tempreture senser i think 04-possible brake vacume 01-is idle valve ,could do with a bigger pic i.e the other end of 05 might have an idea
00-throttle position sensor.
01-idle control valve.
02-inlet temp sensor.
03-vacuum pipe going to?????(where does this go?).
04-vacuum pipe to brake servo.
05-vacuum pipe to purge canister.
03-vacuum pipe to fuel pressure regulator
05-vacuum pipe to purge canister/carbon filter+fuel vapour cut-off valve(can be located at in the right wheel arch compartment trim)
