Technical Need an oil cooler
dsevdaliskarp
I need to replace the oil cooler of my Fiat Strada 1.7TD model year 2000/01.(376 A 3000 ) Its an aluminum piece around 27 cm long, 9cm high and 3.6 cm wide.Also could someone give me the Fiat number for that part.
Just had a look on my parts software and its part number 46479625 - its the same part used on the Fiorino 1.7 TD too...
Thanks Jim,, if its possible could you tell me the price given for the above part and where youre located.Thanks
According to my 2008 price list this part is £224.61 GBP from a dealer here in the UK... seems quite expensive - have you had no luck trying to source a secondhand item?
My thoughts exactly, here(greece) it is priced 400 euros,:mad::mad: no luck yet on finding a second hand item.
Peter, living on a small Greek island has its advantages but unfortunately radiator shops isnt one of them...I have called all over greece trying to get one of these babies used but have not had any success. I also believe that paying the Fiat representatives 400 euros for a piece of aluminum , highway robbery.
Ran over an unseen cut tree stump that caused the oil cooler to come apart at the junction point.(where the hose from the engine fits into the oil cooler, the local welder said he could not weld it properly as it was aluminum.)
Hi, Your looking oil cooler for Fiat Strada 1.7TD, I think you can know more about on search engine like google, yahoo, you can search Fiat parts, Fiat oil cooler, and if you want direct contact then call us at 0872 33 11 247, you can also purchase online.
Hi
I am breaking a r reg (1986) fioriono 1.7 td. I dunno if that helps you . If you want to check via eper for a possible parts match the The reg is R632 CDL. If you also need the chassis number P.M me.
