MYSTERIOUS LEAKING
MYSTERIOUS LEAKING
S
stavros
Hi,bravo lovers!! I noticed a water line on the windscreen from the inside. Is this posible to be the sealant or it has to do with te sunroof?
By the way the roof is not wet.
Many thanks in advanse!
Greetings from Greece
I had this recently too, I just put it down to condensation build-up inside the car ;)
Dan
You mean that the drain holes are blocked?But how it comes inside without the roof getting wet?
no! nothing like that matey!
as long as it doesnt happen too regular you have nothing to worry about :)
Dan
Define 'water line'? Like a drop of water has run down the inside of the screen?
thats what I meant Tom, a bit of condensation that has built up and then made its way down the screen to the bottom ;)
Dan
I get that occasionally, have no idea where the water comes from and its never gotten worse.
S
1
7K
Streak2013
S
J
1
1K
Frank
F
M
2
743
Dark Lurker
