I finished out 2nd overall on the day by 1 point. dead chuffed
Dan
Dan
Hellcat said:Ah looked like a 2, not a 7..
Losing points for indicating when no other cars present? Could understand the 1 by 1 gears thing though, usually 4th to 2nd coming upto a roundabout is normal. In the Tipo 2nd to 4th is quite usual too.
bulldog5046 said:yeah but going up i tend to only use 1, 3 and 5
Skate2create said:The only thing he faulted me on really was how I came down the gears 1 by 1 when decelerating...
That and I shouldn't indicate when there's no other cars around me.
I got the 2nd best on the road, give me credit!
Hellcat said:How will it wear out the box? If the speed is in the range of the gear then its fine to use. I could drive everywhere in 4th in the Tipo if I wanted to. Can pull away from the lights in 4th and its also good for over 80mph..
GhostWKD said:because when you block shift you make the engine labour more in the gear you shift to, unless you really hammer it that is
SkinzCinqSporting said:Im only saying what I was told when I was learning to drive, that block shifting upwards put unnecessary stress on the gearbox. Talk about don't shoot the messenger![]()
Hellcat said::hug:
Not having a go at you - just the IAM..
