About a million things going on and one hell of a few days finally got to work on the van. Most of it is just waiting on things to arrive now:
Started off working on the front seat
Modified Renault seat base although I must have been drunk or blind when I done all the fitting as now the seat does not fit EVEN though it did 3 weeks ago when I started this process.. so now I need to get some brackets made up so this is a never ending project!
Looks OK though:
Seat out and now to focus on the back doors.
Originally I was going to cover the entire doors but I decided to paint them up and ill just cover the bottom panel instead I think it will be a little bit nicer considering the back of the van will not be fully decked out and it's a bit more "dog proof"
Extent of the marks and scuffs on the door, both doors are the same
Took some 1500 grit paper, cleaned them up a little, wiped down with a wet wipe and then gave it a coat of primer
Found the paint code its Fiat 249 white base primer as Fiat suggest makes the finished coat look bright white. Hence why I used grey and I can see where I missed, think this is two scratch coats applied:
Going to let the paint fully harden now over night and ill wet sand it down and give it a final coat.
Inside of the van, had to clean all the glue of my shelf units will go into detail when I have these almost finished:
Next job I bought a new head unit but I need to get some ISO adapters, I also intend on fitting 10cm speakers in the back but that's a job for another day. Today I wanted to get the front speakers sorted replacing them with Pioneer.
Door card off:
Not much to see I think there are write up's on here about replacing speakers anyway:
Old
New
Installed
Both speaker wires where white! No marks or black lines nothing just as white as the van! So I decided to connect them back up left connection to left and right to right as they came off the old speaker once the head unit is off ill trace the cables back and see which is which.
For now though as long as I don't blast them it should be fine i think.
Tested speakers sound is amazing (well anything will be better) idle had the old speakers at 8-9 volume these are sitting at 3
While door cards where off time to add some sound deadening
That's all I got done today have to bake a pile of cakes for daughters school!
