My in-car PC project is on its way
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: My in-car PC project is on i
hard drive caddy ;)
well let us know how it goes, certainly very interesting!!!
The mini-LCD screen
Thanks smartarse...:)
i know its not Bravo related, but i have done a guide for the LCD part of the project, that some of you may find interesting.
takes a deep breath...
You'll probably have to buy only three things to make your own printer-cable LCD: an 'Industry standard' LCD display with a Hitachi HD44780 (or compatible) chipset. (I got a 2x16 character display from maplins for £12. A standard printer cable to take the data output from your PC's printer port to the LCD screen and a Molex (HDD power cable) splitter/connector to power the LCD from your computer's power supply. Some wire and soldering tools are also required. While the soldering is a little delicate, it is not difficult. I will be the first to admit that my soldering skills are quite poor and if I can do this, then almost anyone can. A little practice and some patience is all it takes.
The bits
The first step (as you can see in the picture above) was to remove the plug-covers on the ends of the printer cable. Each cover had four little clips that could be opened to split the cover into two separate pieces. This allows you to easily identify which wires match the pins on the parallel port end of the cable.
A little bit of preparation can help quite a bit in a project like this one, and the next step was to 'tin' the contact points on the LCD's PCB. Simply place the bare solder wire over the contact, quickly push down with a hot soldering iron, and you should get a nice little blob of solder coating the contact.
It should look something like this :)
Next cut two pieces of wire - about 20cm longer than your printer cable - to take the power from the Molex connector to the LCD. Then cut three smaller lengths of black (or whatever colour your negative will be) wire and solder them onto the end of the longer piece - there are three negative/earthed contacts required, and only one positive (5V) connection.
Now the fun part begins - soldering the wires up the LCD - take it slowly and carefully and things should not be too hard.
Work with the Centronics (printer) end of the printer cable - because you'll want to plug the parallel port end into the back of your computer. Applying the soldering iron to the wires where they are soldered to the Centronics connector and pulling gently should be enough to undo the wires from the unwanted connector. Check the parallel port end of the cable to ensure that you are attaching the appropriate coloured wire to the LCD's PCB.
When you have finished wiring the nine printer cable wires to the PCB, it's just a matter of tidying up. First cut off the Centronics connector - the remaining wires are not required. Cut off any extra plastic bits and tidy the end of the cable up with some electrical tape and cable-ties. I also wound the two long power cables around the length of the printer cable and secured them with a fair number cable ties.
Like this
Connect the other end of the two power cables to your Molex adaptor - I cut off the 'floppy drive' connector and soldered the power wires into place. Make sure you use the red 5V line and not the yellow 12V line when wiring your LCD to the Molex connector. (Test the voltage of each of the rails with a multi-meter if you are unsure which to use).
Now that the cable is finished, it can be attached to the printer port on the back of your computer, and powered via a Molex connector from the inside of your computer case. When the computer is powered up, the LCD screen should - if working correctly - display a number of solid blocks.
..and thats about it..all that is left is to install the relevant software, you can use any but i found Crystal fontz to be the best. It's very easy to configure and use.
Phew...
Daz
Re: The mini-LCD screen
:) Now if you DO use the 12v there is a lovely burning smell from your LCD and your nice 20x4 display won't work anymore... ARSE ARSE ARSE!!!
That was a costly mistake.
Started my boot build today, false floor to take the 2 amps and in theory maintain access to the spare wheel.
Re: Re: The mini-LCD screen
i was going to have a go until i realised my mobo doesn't have parallel, seriel or ps2 connectors. i will but these fangled things!!! Bring back my pIII!!!
I've sold all my older stuff as well :( Apart from my 166 for downloads! lol
Still, was looking round a computer fair today and they were selling athalon 800 processors for £15, so could be worth an invest!!! lol
Re: Re: Re: The mini-LCD screen
Look at www.mini-itx.com, very cool little PC's.
I can get in car PSU's for them very cheaply.
Re: Re: Re: Re: Re: The mini-LCD screen
Oops...just read my guide and forgot the important bit...lol
The wiring
1 Earth (Black wire on Molex connector) Earth
2 +5V (Red wire on Molex connector) Power
3 Earth (Black wire on Molex connector) This adjusts the contrast of the LCD digits. Earthing
pin 3 provides maximum contrast. A 10k pot can be
used to provide a variable value if required. (i used a 2k resistor)
4 Parallel Port pin 16 (Green/white wire) Register Select
5 Earth (Black wire on Molex connector) Read/Write. Since we are not going to read data from
the LCD, we can ground pin 5; to set it permanently in
write mode.
6 Parallel Port pin 1 (Pink wire) Enable - Strobe
7 Parallel Port pin 2 (Red wire) Data bit 0
8 Parallel Port pin 3 (Yellow wire) Data bit 1
9 Parallel Port pin 4 (Green wire) Data bit 2
10 Parallel Port pin 5 (White wire) Data bit 3
11 Parallel Port pin 6 (Blue wire) Data bit 4
12 Parallel Port pin 7 (Purple wire) Data bit 5
13 Parallel Port pin 8 (Pink wire) Data bit 6
14 Parallel Port pin 9 (Grey wire) Data bit 7
If you have a backlit LCD (like me), there will be another +5v and a negative to solder.
Please note, the colours of your wires may vary.
Daz
