Some more work being done. Still a non runner but so far.
New leads and plugs,
New fuel pump, a sod to get out
checked fuel pump wiring,
Checked injectors visually and electronically
checked Cam and crank sensors.
Jobs to do
check timing,
check coil packs,
test compression(when I get tool)
then everything else.
Needs a good going over with a wire brush and a good poke with screw driver. Definately will need some welding due to advisories last year.
New interior as many fag burns in the back.
New brake pads I suspect possibly discs and I'll check suspension componets as well. Trying to fit this around work and college will be a nightmare
