Technical  Multipla tow bars
If it helps, Witter's website lists the same towbar for all models of Multipla, 2000 - 2011.
I can't see any reason why they wouldn't be the same, apart from (perhaps) the different bumper. The structure underneath is the same, AFAIK.
F.W.I.W., I bought a multipla towbar from a breaker on e-bay, a couple of years ago, it came from a 2002 model, I asked if it would fit a 2005 facelift model, and he was certain it would, and offered a full refund if it didn't....Surprise, it did.. apparently there is little difference regarding fittings, just need to make a small cutout where bar comes out below bumper. (assume the facelift bumper is a tad deeper that the roundnoses was. But otherwise, all good.
If buying 2nd hand, make sure you get all the spacers that fit into the cross members, otherwise you will need to make some up.
Mine was a Witter one, complete with spacers, nuts bolts, both the spreader plates, electrics, and ball, all for £30 + £10 P&P. Gave it a good wire brushing and 2 coats of hammerite, looked as hood as new..
