Technical  Multipla BMC Change and Bleeding
pgrant5
Hi, I am desperately in need of help. Changed my BMC yesterday on my Fiat Multipla with ABS no ESP.
I placed the 2 brake pipes so that I knew which one was the front, and which ones was the rear, unfortunately after I removed the BMC the pipes moved, so no idea which went where.
I then working on the theory that the pipes will find there own place, screwed them in where they lay. (probably being a numb nuts here!)
I then tried bleeding the brakes using my Gunson Eeezibleed, Started on N/S rear wheel, brake fluid just dripped out very slowly. next O/S rear wheel bled normally next N/S front again no brake fluid just very slow drip, next O/S front bled normally.
I need a diagram of the brake pipes along the bulkhead, and the to the BMC, and any ideas why the brakes did not bleed properly .
Many many thanks in advance for all your kind help, incidentally most of the work was carried out by my Wife!
