Technical Multipla 1.6 16V Vialle LPG G3 Mystery
MultiRacer
Netherlands
Dear people,
I have a giant issue with my Multipla. I was driving on an 80 road when suddenly my cambelt comes loose because of the tension thing that broke. 15 valves where broken... So I bought a used cylinderhead including camshafts and such... And a new tensioner. Since everything is placed on its place, I have the check engine light burning. It flashes all the time and beeps 2 times every 5 seconds. And doesn't stop, it really doesn't. The car is revving to random RPM's when stationary. And when I put gear in 4th, The car will run 30KMPH without touching the gaspedal.
Today I removed the air intake to the cylinder. I cleaned it with high pressure air and found out that the cylinders are receiving false air... Through the sides of the LPG Injectors. So I sealed the injectors but the problem was still there. I also used my OBDII to find out what the problem is but no DTC's appear. Still the check engine light is flashing and the thing is beeping. I am getting tired of this car and am completely out of options here. I need to sell this car as soon as possible because I am a student without a job and cant afford the taxes and insurance.
Things replaced: Water pump, Dynamo, Air intake thing that is attached to gas pedal (2 times replaced no works), Valves, Cylinderhead, Oil, Coolant. Car runs fine on LPI as well on Euro 95 petrol. Also have driven 120 KMPH with it, runs fine.
Could someone help me?
VIDEO:
