- Joined
- Jan 6, 2015
- Messages
- 294
- Points
- 122
My Multiecuscan 2.9 with full register and my ELM327 1.3V interface to clean error on engine of Punto 1.9JTD after finished clean my EGR valve. The picture is coming up "ELM327->ECU Failed" on Engine, ABS and Climate control but it works fine only on Dashboard and Service reset.
I have already remove one resistance what it shows on Multiecuscan website which is not make any different.
Test my computer it shows:
Test Interface all Response OK
This Interface is compatible with ELM327 1.4! should connect properly with all CAN modules
Setting interface: ELM327 1.3V 38400
Prolific USB to SERIAL COMM PORT:
BITS PER SECOND 38400
Data bits 8
Parity None
Stop bits 1
Flow control None
Advanced Setting for COM5
Use FIFO BUFFERS is tick
Receive buffer 14
Transmit 16
COM port number: COM5
I can't see anything wrong with it?
It works in January after clean error was replace fuel filter but now something gone weird?
Try on my brother's Punto and my sister's Punto it works fine on Bosch EDC15C7 but my is Bosch EDC16C
Data bits 8
Parity None
Stop bits 1
Flow control None
Receive buffer 14
Transmit 16
