Technical Mpi rough idle / flat spot / poor down changes
ronnieronson
Bring On The Trumpets!
Hull
Ok - done some work on the car today and think i'm getting somewhere with my problems...
The idle problem, and the power / downchanges issue dont seem to be related - and here's why I think that:
Just had all four wheels off (tyre rotation day :p) - and noticed that my front brakes are sticking excessively, to the point where there is zero gap between pad and disc, and the hub is very very very hard to turn by hand!
The problem is admittedly worse on the passenger side - which would explain why my car insists on drifting left if I relieve my hands of the steering for a moment.
This would explain why there is a slight problem with acceleration - but more importantly why the car slows down very sharply when doing downchanges.
As for the idle problem - I've swapped the map sensor out yet again today, which as far as I can tell hasn't changed a damn thing.
Symptoms =
rough idle - only 500rpm or so - judders like a v8 and seems to be "hunting" quite eratically.
Other than that, the car's drunk a wee bit of oil in the last 3 months (2.5k miles) - but not what I'd call exessive.
Fuel consumption is quite high - but then if the brakes are jammed, that's not going to be a big suprise (getting approx 250 miles to tank = 32mpg approx).
To cap it all - having just rotated my tyres, I drove round the block for a bit of a test run, and ran over a bloody screw - which has ripped a lovely hole in one of the two decent tyres I had :cry:
:mad: :bang: :(
I dont know your car.
But could the idle probs be a knacked stepper motor?
I think I'd suggested this before - someone did dismiss it, but in all honesty I've no idea how to check it :confused:
This is really bugging me now, as I want to get the car running nice (thinking of selling her and getting something in the two seater variety :D )
Can sort the brakes nice and easily - so then basically I've just a tyre to sort, and this bloody idle problem.
Interestingly enough my Friend Rusty has the same sort of thing on his 2001 Schuey - had crossed my mind that this may be perfectly normal on the MPI engines... I'm sure someone will confirm / dispell this theory...
