mp3 player into headunit aux socket
G
Gerry
My kids have got mp3 players. My Aiwa headunit plays cdr/w discs, but not discs burnt in mp3 format.
Is there a cable I can buy which would connect the mp3 headphone socket to the aux in socket of my headunit? If so then presumably I could listen to all the files on the mp3 player rather than the 15-20 tracks I currenty can with normal discs.
What do you think? Thanks
Gerry
Penicuik
Brava 1.8 ELX
If there is an aux in socket on the front of your headunit then its simple, you just need a cable with the required plugs on each end. If the socket on the head unit is a standard 3.5 mm stereo socket, and the same on the mp3 player, then a standard 3.5 mm to 3.5 mm stereo cable is all you need. try a local TV shop, or you could get them in maplins etc. or make one up using two old headphone leads..
Owen.
Thanks, Owen
I'll take a look at Maplins this weekend.
Gerry
C
539
clive
C
A
294
Adrian Bravo
A
C
6
440
M
A
2
353
K
F
6
427
steve
S
