stevie1604
- Joined
- Feb 28, 2011
- Messages
- 2
- Points
- 1
Hi Guys
My girlfriends Seicento has failed its MOT on the emmisions twice now, after the first failure I was advised to fit a MAP Sensor so done this and put in in for a retest only for it to fail again!
I have been told fitting a new lambda sensor might be the answer but don't want to keep fitting parts and retesting time after time. I have included both emmision readings below, if anyone can help us it would be greatly appreciated.
Testing station said they had the engine red hot, with the fan running, lights on and hrw switch on as this helps with the mapping!
FIRST FAILURE
DESCRIPTION Limits Actual Value
Engine Oil Temperature Min 80 Deg C 80 Deg C OK
Fast Idle Test: FAILED
Engine Speed: 2450-2950 rpm MANUAL CHECK Pass
CO: <= 0.3000% 0.018% Pass
HC: <=200ppm 14ppm Pass
lambda 0.970-1.030 1.273 Fail
Second Fast Idle Test: FAILED
CO: <= 0.3000% 0.260% Pass
HC: <=200ppm 17ppm Pass
lambda 0.970-1.030 1.208 Fail
Natural Idle Test: PASSED
CO: <= 0.3000% 0.017% Pass
Overall Result: Exhaust Emissions Test FAILED
SECOND FAILURE
Engine Oil Temperature Min 80 Deg C 84 Deg C OK
CO: <= 0.3000% 0.822% Fail
HC: <=200ppm 43ppm Pass
lambda 0.970-1.030 1.144 Fail
CO: <= 0.3000% 0.010% Pass
HC: <=200ppm 8ppm Pass
lambda 0.970-1.030 1.100 Fail
CO: <= 0.3000% 0.009% Pass
FIRST FAILURE
SECOND FAILURE
