Technical  More power..
RALLY1NEUK
NEWCASTLE
Re: more power
We Talked to K & N about air filters and ram air/Boxes
They said the air box should hold two thirds of the air requied at max air request.
with a smooth flow of air to give a balanced air flow to each cylinder or other wise the engine will go out of balance at higher revs.The air should be of correct flow to
cause correct mixing of the gas & injected fuel.Cool air through a intercooler would also help & slightly moist which causes steam and more compression.
Gas Flowing a head and a 285 profile cam upto a Hr320 cam would also help.
Gas Flowed exhaust manifold from ANSA or Janspeed gives about 8 - 10 %
extra power.
