Why has it got a snorkel? Its got an unprotected k&n air filter on the air inlet.
Isn't the idea that it draws air from high up out of water's reach, rather than below the air filter where the standard set-up draws it?
Or it could be that they think it looks good!![]()
To have a proper working snorkel the air filter needs to be enclosed and connected to the snorkel so as to prevent water ingress. That snorkel can only be for show.
Your all wrong...
It the new Eco friendly mod which fiat will be rolling out across the range.
Water rolls off the roof, down the drainpipe and is collected for later use on your lawn or plants during times of drought.
£2,250....![]()
1990 Fiat Panda sisley with the famous Puch 4x4 sytem they were designed and fitted with.
Sold with just under 12 months MOT and 6 Months tax.
84,000 on the clock.
quick summary
Getting rare these days, well one with original sills anyway, i has had minimal corrosion, few patches of welding here and there but nothing substantial or scary. The carpet was replaced with rubber carpet in its place, the sound deading and inner sills are mint so has not seen damp or moisture inside.
Its had front wheel bearings, pads, bushes suspension arm bushes..... list gos on. its been raised by 2" all round for ground clearance wich is nice and subtle.
sump gard has been plated with alluminium chequer.
Drives well and performs well off road (steep hill in wet field)
The arches have been touched up but again are solid, the passenger door was replaced at some point because the bottom had fallen out.
This comes with the usual sisley bits, i will upload better photographs at some point too.
Its also had cambelt, service, brakes serviced, diff and gear oils changed etc....
4xoff road tyres and wide wheels
4xroad wheels and tyres
box full of spares and bits and bobs.
Not much else i can say without a viewing so please do come and have a go.
Any one have any more info about this?
Im off to look at it tomorrow
