Mobile ECU Remapping
JIW8880
Hi guys has anyone heard of ACE Remapping?
I heard they were a good company go to go with for a remap, plus they are mobile which would help me out while being at work.
One I prepared earlier :cool:
Actually you guys missed out G-Tech (or similar).
However mapping on a road usually means a generic map with specific modifications or a standard car otherwise it is...
1. Not legal
2. Takes many many hours
3. Not really a proper remap (unless it takes days)...
Nearly all doorstep mapping involves a shabby (you might as well buy a chip...) map.
Anyway this is most likley money sponge so I'll go with the general concensous.
As for the reply from Ziggness, a proper remap needs a rolling road and a real road. A rolling road doesn't cover it unless it happens to have a wind tunnel close by. :)
1. Not legal
Hows it not legal :confused:
Because you need to try and simulate all possible loads at all possible speeds. I think that it's fairly obvious you can't do that unless you live next to an Autobahn covered in hills and corners with no speed limit...
Secondly you of course need to have a passenger doing the mapping so you can concentrate on your driving, pretty obvious it's not safe to drive while staring at a computer...
Would you want someone driving around in your car at insane speeds on public roads??
What your talking about on the road mapping is actually called live mapping and you can only do that with jap cars.
European cars you can only flash map where you read the file adjust it and write it.
Live can be on a road or a rolling road, it just means real time. It really makes no difference adjusting a map is remapping regardless of how you do it.
You still have to test it after you've made an adjustment and see if an improvement has been made, so how you going to do that. :confused:
Whether you map it in real time or not you still have to use something to verify the results and see if they have made an improvement (or not). Funny my car is European yet I map it in real time...
Hmmmm maybe we do know what we're talikng about... :confused:
Mmmm. So my MR2 doesn't have a Japanese simulucrum of a Bosch management system? If I fitted an Emerald ECU could I live map it? Will the chip out of my Cinquecento taste good with Cod?
