I posted a while back enquiring about how to wire in the 100w factory sub to a 1.2 8V without the rear wiring loom. I never got round to fitting it, but the other day I managed to track down the fixing kit.
The sub is now in the back, with all wires ready to attach - but I'm a bit stuck with 2 parts - the first is the white 8 pin block behind the head unit. I've found it, but does anybody know what one is the fifth pin? The one I thought it was doesn't connect to anything, so I was ready to crimp onto the other red and black cable - however, the instructions mention a grey wire which threw me a bit. Attached are the instructions and picture of the block I believe it is!
The second problem is a 32 pin connector that apparently exists. The instructions aren't very clear, so I can't work out where it is. I have a spare 8 pin connector hanging next to the driver footwell, but I don't know if I can use it as an alternative. Does anybody know if this 32 pin connector exists in a 1.2 8V without the 'advanced setup sound wiring loom'?
