Sorry to hear that man. To gain access to the headlights you need to dismantle the front grill and bumper. To dismantle the grill you need to take off the plastic cover from above, then remove the grill and after you can remove the bumper which has screws up, sideways and down also. Good Luck !
P.S. if you take the headlight off, be sure to make some signs at the screws which should help you when you mount it back, or else you will need to re adjust your headlight low beam.
P.P.S. if you take off the driver side headlight, when re mounting, be sure to plug in the wiring connector first, because if you mount the headlight without it, after this you will have to remove the airbox to plug in the connector.
