Technical Misfire occurred suddenly.
Steph3071
Just getting home from a 4 hour drive on some very hilly terrain and I noticed the car had started to run rough and clearly misfiring.
Any attempt at an Italian tune up results in the engine management light coming on.For a few seconds after starting the car it idles smoothly, but soon returns to lumpy idle.
I put it on MES and get
P0300-98 - Ignition failures recognition - Component or system over temperature.
P0303-98 - Cylinder 3 ignition failures - Component or system over temperature.
P0300-92 - Ignition failures recognition - Performance or incorrect operation
P0303-92 - Cylinder 3 ignition failures - Performance or incorrect operation
Restarting when cold doesn't resolve the issue.
Switching a plug wire didn't move the problem to a different cylinder.
Pulling the plug wire for cylinder 3 and leaving a gap for the spark to jump gave a nice loud crack as the coil fired for cylinder 3.
I've ordered some spark plugs, but not convinced this will cure the problem as it idles fine for a few seconds on initial start up.
Anyone got any other suggestions?
Model
Punto 1.2 8v
2012
Mileage
186000
Moderators, please move to the correct Punto thread. I posted in the Arbarth thread by mistake! Sorry.
