Technical  Misfire cylinder 2.
Barney Rubble
Coventry
I’m currently looking at an issue with a 2010 Panda 1.2. It has developed a misfire on cylinder 2. P0300 Misfire detection and P0302 Ignition malfunction cylinder 2. Using Autocom software.
The car has just been serviced by a garage who have replaced the spark plugs and HT leads. I have fitted a new coil pack and swapped the spark plug and HT lead to cylinder 3 and the misfire remains on cylinder 2. I have carried out a compression test, and all cylinders are 225 psi. Disconnecting injector 2 has no effect on the misfire at idle. I have connected my strobe light to each individual HT lead and they all fire at the same rate and intensity so pretty much ruling out an ignition/ecu fault. The connections all appear good and I have carried out a wiggle test on the wiring which doesn’t affect the idle. Coil charge times were all pretty equal but I can’t remember the exact figures and injector pulse was around 3 ms and all 4 were pretty equal, but again I can’t recall the exact number. Number 2 spark plug is always wet after a bit of running so I’m leaning towards an injector stuck open but it doesn’t show on the pulse width, that said would the ecu know if the injector was stuck open?
Anyway.. has anyone had the same issue?
Thanks in advance.
Model
Panda 1.2
Year
2010
Mileage
120000
Thanks for the response.
That was on the to do list but I was concerned about damaging the ‘O’ rings on removal and leaving the car undriveable as they are using the car everyday. Maybe I’ll try and get a set of ‘O’ rings beforehand.
My experience with misfires that it's not necessarily the sparkplug it's indicating.
The misfire is without doubt cylinder 2 it’s just the cause that’s the issue. I’ve found a set of new injectors on eBay for around 35 quid whereas an O ring kit is 17 quid. Does anyone have any experience with these cheap eBay injectors?
Don't
Spray pattern and flow rate are likely to be way out
O rings not needed
Done loads never had one fail, no guarantee, but odds are in your favour
The nozzle was visibly dirty in comparison with the others. It may have responded to a clean but it’s got a new one now and runs like a dream.
