- Joined
- Jun 1, 2006
- Messages
- 714
- Points
- 202
daves settings are:
Trig pos A: 3
Ret: 13
Trig pos B: 33
ret: 43
using them settings i get a stable RPM reading, but i've not had the car fire yet. Need to check my valve timing isnt 180 out!
Dave, when u say check with a strobe - what do you mean, i know bung it on no1 ht and then point at the crank wheel.. but i don't know what im looking for. I've never used a strobe before!!
You need to make a white mark (tippex) on the crank wheel ten degrees btdc and make a mark on the block (check this its in the mega guide). Then as you turn it over the strobe will pick up the mark, they should align.
Even with timing out mine still fired, backfired, spat back and all sorts. Something should happen
