:worship:
This request appears in 2 places as I am aware the it is quite technical. I'll copy responses across - thus duplicating but, in disparate areas
Someone to check my ideas please, and correct them if wrong.
I'm sure other people will start using Msquirt when the wiring is sorted and we have a base map Rich Cinq is using it already!
First section - what I think......
followed by 2 wiring diagrams...
Hi
This is how I have worked out he megasquirt to punto loom.
Is there an expert sparks who can check it for me:worship:
Will help future megasquirters no end.
Ignore the light green and light blue wires on stepper ICT as these only apply to the mk2 megasquirt with a v3 board. I’m using a Mk1 with v3 board and 29v firmware. This utilises pin 36 and pin 31 for coils.
Wiring for a v3 megasquirt board – with wasted spark upgrade using pin 36 for coil A and pin 31 for coil B.
I think..
Mega punto ecu connector
Pin 20 > pin 31 intake air temp sensor
Pin 21 > pin 13 coolant temp sensor
Pin 22 > pin 30 throttle potentiometer (?uncertain on this)
Pin 23 > pin 29 ( could be pin 12 but I think thats an earth?) lambda
Pin 24 > pin 11 (or should this be pin 28? Tach. crank take off, tdc.)
Pin 25 ignore
Pin 26 > pin 14 (please check?)
Pin 27 ignore
Pin 28 > pin 26 link to pin 14 to give + out to injectors
Pin 29 ignore
Pin 30 > relay for Fidle (no direct correspondence but could connect to stepper wiring which will be connected to a bosch or pwm idle valve?)
Pin 31 > pin 1 (coil b?) This is the wasted spark upgrade out. Not shown on v3 standard diagram.
Pin 32 , 33, 34, 35 > pin 18 injectors
Pin 36 > pin 19 (coil a?)
Pin 37 > pin 26 (live in on spi but not on sporting so sporting would need this added to car loom?)
Pins 1 through to 6 ignore
Pin 7 > pin 28 (or should this be 11?) tdc tacho sensor
Pin 8,9,10,11 and 19 to > pins 17 and 16 bridged
Pins 12 to 18 ignore
Phew
If anyone can help me with this I would be very grateful – I’ll even pay !
I have included v3 wiring diagram and a punto diagram. I’m working from the Haynes diagram
And
Thanks:worship: :worship:
