- Joined
- Feb 16, 2005
- Messages
- 5,983
- Points
- 988
Found out yesterday about that. There is a small port on the gearbox, which shows 0, 5, 10 and 15 degrees timing marks. Borrow a timing pistol, set Fixed Advance at Fixed Timing (at More ignition options) and Timing for Fixed Advance at 10 degrees.
Then, you can start your engine and check what the gearbox port shows, and if necessary, go at Tools -Trigger wizard and set the correct value. If the value is more than +/- 6 degrees, change a tooth (or angle) at Trigger wheel settings.
I am having problems getting mine going, so thought it best to go to basics and check the simple stuff....like the timing.
I bought a gunson advanced strobe, set fixed advance at 10 degrees, put the pickup on lead number one, an opened the inspection port.
I presume i'm looking for the notch that is in the flywheel as a reference to the markings on the gearbox?
ie. this mark (thank goodness a bit was left after the lightning
When i run the engine at 10 degree advance though....the mark is nowhere to be seen!?!?!?!
What could be wrong here? I'm all confused lol.
Kristian
