Technical  mearea weekend ecu problems
kc jones
reading
Hi there i got a problem with the ECU not sure if its corrupt or wiring problem.
Ive been getting the fuel injector light up know and a gain i had the temp sensor changed last year.I took the car to a diesel specialist to have a diagnostic check but he was unable to download any info fault codes.has my ecu had it.
The car is running fine any advice please
cheers
1999 2.4 jtd130
Thanks for reply
I took it to the same garage that came up with the fault codes that i required a temp sensor and had tried other garages before this with the same problem reading the cdu.
cheers
Hi there
Took the marea 2 another specialist and managed to reading the ECU, i need a water temperature sensor and a thermostate,
Can i only get these parts from a fiat dealer
cheers
kc
Hi everyone
Ive been looking for a thermosat for my marea weekend 2.4 do you have to buy the hole unit.The cooling temperature sensor looks straight forward.
cheers
get them from a dealership, If the thermostat is part of the complete housing (like the other diesels), you won't get them much cheaper anywhere else.
Hi everyone
cheers
Have a look at the Bosch E-catalogue for the temp sensor, that'll tell you which other cars were fitted with the same sensor & the Bosch & OE part numbers. . You should be able to source that from a good motor factor. Motor factors worth a try for the thermostat too.
Hi everyone
had the temp sensor fitted but yesterday the fault re-occured red fuel injector light dont really know what to do next but car is running fine
cheers
kc
hi there
I went to work after my previous post and the injector light went off when i started the car up.
I went to a specialist to fit the sensor and he cleared the code with diagnostics,also had glow plugs fault code which he said no to worry about them and said they are a pig to change.
no fault lights on the dash on me way home so what now?
cheers
kc
