Styling  MAREA WEEKEND seats HELP
Unless someone answers who has already done this, the only thing that will really answer this question for you is to remove the seats from both cars and compare them side by side.
You may find that the subframes are the same, especially if both cars have been built on the same floorpan, that would be a huge bonus of course.
If the upholstery is the same size and shape but the subframe is different you may be able to remove the upholstery from the Alfa seats and fit to the Fiat.
If you have never removed seat covers before it is quite simple, the covers are normally held at the bottom/back with metal clips or rings, just turn the seats over and have a good look and you should be able to see how to do it.
Good luck:)
my Bravo has coupe rear coupe rear bench because the Marea one didnt fit ,
so was just wandering if the rear bench from the alfa 156 fitted as they essecially the same car.
i want Alfa GTV front Seats . i know they fit with minor mods so just need a leather rear bench
