Technical  Marea weekend r reg, 1998,A/C
imthejoker
Joker by nature......
Essex
Hello , im wondering what refridge gas is used in the system in my car-can anyone shed some light on this pls , many thanks
Joker
It has to have oil as well, the recharger should have alist and add the right amount after re-gassing. A need to re gas can be a symptom of something else but worth a try .
Bulldog/renegade i knew u's 2 would have the answers . Where would you guys recomend that i take it to be inspected/repaired - obviously not Fiat i guess - iv got an ad from them 'regassing for £30' -what do you's rekon pls??
Joker
I found that out the hard way after paying for a few re-gassings and eventuallyfinished up at Basingstoke (long story) where an independant who was honest and knew something about it helped sort my car. Azure Air. I had to think long and hard but eventually put a new compressor on, I'm sure the original was blown by a failed triple switch that the local clown could not be *ss*d to diagnose. In the meantime I did get some mileage from the sealing gloop they can put in, but on my experience I would not recommend it. The £30 re-gas has to be a sales come on.
http://www.basingstoke.co.uk/info/336/
Thanks for that mate , i think it just needs regassing as it used to work but not using it for a while then turning it on its cool but not 'cold' like it was-, well im hoping it just needs gas:confused:
Joker
when i had aircon (in my first marea) i bought a re-gassing kit from halfords, it was £30-40 from memory and it did the job.
if this is the first time you have had issues i would try a regass first, IMO its probably just escaped over time.
you can probably get one of the kits cheaper on ebay.
Ry
Seems like a good idea thanks Ry , didnt even think of harlfords , il have a nose at both-thanks again
Joker
Hi Guys.
These diy re-gas kits are they any good?
At the garage they apply vacum for 10 min before adding 600g of R134a and oil + tracing color.
Does this kit only contain R134A or oil as well?
I've changed nearly the whole A/C system, compressor, most of the tubes, the receiver drier and the triple switch.
But i need to re-gas nearly every year (2 years old original compressor leaking again).
So i would like a cheap re-gas sollution.
Michael
Miggard , iv no idea about the diy kits personally but bulldog rates em , when iget paid in 20odd days im off to get one-thats the plan anyway!!
Joker
