TD100, accelerator (fuel lever) position sensor fitted on top of the injector pump (above the accelerator lever). it could be worn out, but check the wiring first before condemning it. check the supply voltage, earth and sensor output voltage using a multimeter. then check the signal is getting back to ECU..
