Technical  marea speedo fault?
kc jones
reading
Hi guys ive a intermitant fault with my speedo i went over a road hump on my way 2 work my dials went dead fuel guage,speed,amps,temp then on the way home they were all working. marea. 2.4 jtd a loose wire somewhere.
cheers
mick
hi guys i need some help with this fault on my marea weekend 2.4jtd nothing is working fuel,speedo,rev counter etc is it a fuse or has the dash have to come out the millage is working lights etc.
cheers
mick
well start off with the fuse anyway.. look up the manual for location, but I think its marked "servizi" on the fuse panel cover. then if you have a multimeter, search for/download the wiring diagrams for marea and check for correct supply voltages/earths at connectors of the cluster. If all present, cluster is probably faulty, but should be repairable
Thanks for your reply
Bad news:cry:
the garage i took my car to said i need a new dash they checked the wiring and fuses and said the clocks are knackered basically the dials stayed up a few seconds and dropped .where can i get another dash,can the cluster be repaired should i get a second opion and where can i get one for a 1999 t 2.4jtd
fiat quote £600 + Vat for cluster ;(
cheers
mick
I have found a instrument cluster for a 99 T marea 1.9td estate would this work in my 99 T 2.4 jtd 130 hlx if i does would this wipe out existing millage otherwise i found some sites that refurb instument clusters
cheers
mick
