General  Marea Oil Leak
carlday
Hi
I hope someone can help. My marea has an oil leak from around the oil filter has the marea got an o ring by the filter? if it has could it need replaceing if not any ideas what it needs to stop it.
Carl
there is a rubber gasket on the filter, if it dropped off during filter fitting then you will have a leak no matter how much you tighten it. if tightening doesnt work that would be the most likely reason.
