S
stephend
I dont use the Rat as much as I should, and as a result the little niggles it has I dont tend to let them get me down, however I think I have a big (read expensive) problem,
A little back ground info.
I changed the slave cylinder about 8-12 weeks ago and all was fine for about 30 miles, then it was hard to get into gear again, I assumed I had not bleed the system fully so I attacked it again, this seems to have sorted the problem for another 30 miles! Now I have bleed the slave again (this time using clear pipe) and im 100% sure there is no air in the system.
Now, when I press the clutch pedal down I have a slight whining noise, coupled to the fact that I cant select first easy and it will not go into reserve gear while the engine is running. If the engine is off I can get gears very easy. When driving I have no problems at all, it goes in all gears easy and has no lack of pull or slipping in any gear.
So what do you think it could be? Clutch knackered, or clutch master cylinder? How can I tell if it is the clutch?
And my slave cylinder was completely shot, it fell apart when I removed it!
Any help and suggestions welcome.
As always thanks.
Rat is back on the road
... New bits coming soon!
As always thanks.
