Technical  marea fuel injector probs
tintin21
hi to all
this is my first post on the forum so here goes!!
im the owner of a 51plate marea sx with a flashing engine management light, ive taken this to a main dealer to put on the diagnostic machine and found that its a fuel injector number 3 problem, my first q is are these easy to remove by a non mechanically minded person would the cleaning of the afore mentioned injector cure the prob or do i need to fork out and buy a new injector and pay to have the pleasure of a garage fitting this......:eek:
Now ive got that out the way, i didnt realise that there were that many mareas out there as around this way they are like the preverbial hens tooth:D
looking forward to suggestions and ideas on my prob.
ps does anyone else get annoyed by the sunvisors on mareas???
ta
Tintin:devil:
Simplicity to remove - disconnect the lead by pulling off the retaining clip then it merely pulls out
i assume this is a 1.6 model. you need to remove the upper inlet manifold and the fuel rail to get the injectors out but its easy enough. there are detaield instructions in the bravo/brava section if you do a search.
are you sure you're talking about an injector? they are not that easy to remove.
Yes - remove the rail (2 bolts), pull off the metal retaining clip, pull off cable pull out injector
yes it is the 1.6 engine, quite a common fault im led to believe and im lucky mines lasted 80k :). was there ever a recall on these as its a common fault on mareas and bravos/bravas
:bang:
