Technical Manifold to Servo Vac line
Just a quick question,
Does anyone know the internal diameter of the vac line that runs from the Manifold to the servo? Normally i would measure it myself but am not near the car at the moment and need to get one on order ASAP as the one on the Turbo has collapsed :eek:
Is that an original one or a different replacement? Ive found oil pipe to be a good replacement.
It is not the origional one,
I was just hoping if might be the same size as the braided line i've got comming for the oil breathers (19mm iirc) as i've ordered a bit more of this than i needed, if it is i can use that and just get hold of and extra couple of hose ends
just my luck it won't be though :rolleyes:
IIRC its about 12mm ID. I had to replace the really hard plastic stuff on mine and I couldn't so I used silicon vacuum hose with an 8mm ID and its stretched over the two ends (manifold and servo) quite well. I tried to get some 10mm ID silicon vac hose, but not easy stuff to source
Edit: actually its about 12mm ID at the ends, but the main ID along its length is about 10mm
Edit again: just tried to find my old vac pipe to measure, but can't find it now, but i have measured the silicon vac pipe and its 8mm id with 2mm wall. Its bloody tight getting it on the manifold end though, 10mm vac pipe would be just right.
