chlblnz
- Joined
- Mar 16, 2012
- Messages
- 59
- Points
- 22
Having a small issue with starting my 176B9000 punto sporting engine up for the first time.
Bit of back ground. I am putting the above engine into an old fiat panda. All in and cranking but not starting.
I have recently had the ECU decoded and the fuel pump has begun working (result). I have checked and there is voltage going to the relay both constant live and under ignition on certain pins. There is no voltage going to the coil pack though or the injectors.
Would I be right in saying the relay is done for? Would anyone know where I can get one as my local Fiat dealer hasn't a clue. Which is odd I thought.
Thanks in advance
Will
Thanks in advance
Will
