This is getting interesting now.
Ok, I don't know how to clean maf sensor but I would LOVE to. Please gentleman, do not take me wrong here but there is something that doesn't make all the sense.
That diode you are talking about, from an electrical point of view - and as far I remember from my classes - will not change its electrical behaviour depending on the amount of air going through/around it. I saw that diode on my old maf and it looks a standard diode used in AM/FM radios. Special diodes can change their electrical behaviour (conductivity) upon different light conditions or temperature conditions. And that doesn't seam to be the case either.
So, I would guess that the air is actually measured in the pins at the end of a small semi-open chamber on the tip of the sensor body (not the tube). I would imagine that those pins would have an alternate signal and depending on the air density the conductivity would change... et voilá.
The fact that those pins are dirty, explains the faulty behaviour of the maf... I think. Now, it doesn't make much sense that the maf stops working if you rub it. Unless, the pins are coated with a noble metal (e.g. gold or smth else).
Well... this is just some food for thoughts really, but in case you have the formula to fix those nasty parts, please advise me. I would be very happy to know and fix my old maf (the current one is not getting any better also).
Cheers,
Afonso
