The element in the MAF sensor is heated so it is definitely NOT advisable to spray anything inflammable into it if connected with engine running - a large BANG may well be the result!
I would not advise buying a cheap repro sensor, that's exactly what they are - cheap - and no sensor will be better than one of them. Much better to disassemble the MAF and carefully clean the 'wire' element with Isoproponol alcohol. There is also, from memory, a glass zener diode which does not need cleaning.
You can disconnect the electrical plug to the MAF without any ill effects.
The usual suspects for the engine smoking is the EGR valve, turbo boost valve & associated plastic pipes of the turbo boost valve ( little black box that the orange and black pipes fit to. It's adjacent the air filter box at the bottom ) check them for splits & perforations. The turbo actuating arm is also prone to ceasing - located on the bottom of the turbo vacuum reservoir that the orange pipe connects to.
