when lowering theres a few factors to take into mind,
do you live in a area full of "sleeping policemans"?
are you after looks or looks + practicality (e.g. handling)?
if no to question 1 and looks = slam it
if yes to question 1 and looks + practicality = 50mm (max) front/rear, this will give the car a nice look while keeping practicality of the car, but bare in mind just go slow on any bumps, dont go flying over them, but that should be common sense to anyone, even when not lowered it can bugger your suspension (eventually!), if you're on a tight budget then opt in for 30mm front/rear, but also remember the punto bum already sits low its just the punto face sits high...
when lowering its all about what you can afford and what you are trying to achieve,dont go crazy and damage your car in the process, think long and hard what you want the results to be like, check out a few punto mk2s on here to get an idea what you want yours to look like, theres plenty on here that have been lowered from subtle lows to full on slams
you are wrong cause punto geometry is till 3cm of lowering
then the control arms are upside down so the geometry is gone...
if you notice even kit car punto or s1600 are n't too low but lowered about 20-25mm!!!! which is the best!!!!!
for handling never lower than 30-35mm
wrightyy has 50mm springs on and i believe it has no drawbacks on handling, then theres someone ashjj thats on 50 i think, no drawbacks, ive even test driven a punto with 50mm springs (a close friend of mine) and i took it around the block a few times and the handling was fine, but speed bumps were dreadful
i was also told even when lowering, the punto bum raises....
around the block you cant see the handling!!!!!
its like saying, i've got a used condom that'll do!
