So this was a busy summer for me, little car had its color changed from yellow to red. Among others i installed a lowering suspension kit that lowers that car about 3 cm along with stiffer shocks. Quit comfortable on the road with tire pressure set to 19/24 PSI and there is room for lower. Anyways lower end sits really low and tires are touching the fenders inside on tight fast corners. Front end (reversed eye ends) seats higher as you can see on the lower photo. Two questions, how i can gain 05-1cm at the rear? Is there any accessory i can buy or fabricate something?
Also the use of the preload tool for the frond leaf is just for installation since the bow of the leaf is big and you can't attach it to the leaf mount without reducing the bow?
I just install it with my jack and some load on the trunk, will the use of the tool make it sit even lower you think? I have fabricate a tool but didn't used it in the end because it was needed some adjustments. Photo is before and after lowering.
Thomas
Thomas
